Oldtymeflyr's avatar
Oldtymeflyr
Electric Trolling Motor Battery Charging
I am trying to figure out the best way to charge a 12v battery that I use to power an electric trolling motor.
Our main boat engine's electrical system does not have the capacity to charge the trolling motor battery.
Our TC has 180 watts of solar panels, approximately 17 volts, going to a Samlex a PWM controller rated at 30 amps charging two batteries. Right now the TC has two 12 volt batteries, but I can switch in two 6 volt batteries.
We do not have an inverter. Our current solar system works well and we have all the capacity we need.
We are usually off the grid, boondocking, when using the boat.
Naturally we need to charge the battery in the evening or at night.
I have thought about getting an inverter to run a battery charger and let it be at that. I have also thought about just rotating the 12 volt trolling motor battery into the camper battery bank and see how that goes, a little inconvenient.
Any comments or suggestions?
Rick
  • I would make some quick connect cables and swap batteries every day.
    Anderson connectors would work great. Connector on the boat also.
  • Don't use the inverter. Connect the battery to your other batteries when you need a charge. I'm sure others might have another idea.
