wanderingaimles
Jul 21, 2022Explorer
Electric TT
A group is apparently working on a trailer that can make up for some of the shortcomings of the Electric trucks. Lightship website
Gdetrailer wrote:Reisender wrote:QCMan wrote:
This begs the question of how you charge both at one campsite. Granted, you may now be able to go 150 miles between charges instead of 90 miles with just the tow vehicle but now you need to rent two campsites to charge them. Electric vehicles are in the future but current technology is being forced to do something it is not advanced enough to do.
Charging at the campsite is nice but not necessary. Lots of DC fast charging out there and more all the time. We top up when we can at sites but rarely suck up more than 25 to 30 kwh overnight as we are always on 30 amp sites. I suppose one could rent a 50 amp site and charge more. I suppose it also depends on the campgrounds charging policy. Surcharges etc.
Should be interesting though. I wonder if future pull thru sites at DC fast charging will be able to charge two vehicles at a time. It would make for a quick charging session essentially doubling the charge rate.
Once again, you are comparing "apples to oranges". What you get from your small scale EV/trailer combination is vastly different than the reality of what happens when the vehicle and trailer are scaled up to real world sizes and usage.
I would recommend that you take a look at one of the first real world tests of a Ford F150 lightning with a 6K trailer in tow..
HERE
The video is a good real world comparison but does have several shameless plugs for their youtube channel sponsors you can forward through.
Cliffs notes version of the video..
F150 lightning (EV) towing vs GMC Sierra (Gas) towing
Setup-
Both towing exact same towing 6K lb trailer at the same time on same route, speeds and conditions.
Both battery and fuel tank are filled to 100%
GMC has 24 gallon tank
Lightning 282 miles non towing range with full charge, display estimated 160 miles towing the trailer selected with full charge.
Ultimately had to cut trip severely short due to less range than originally estimated and no charging stations close enough on their route that they could make it to and had to turn around and backtrack to the nearest charger they could find. Vehicle power (acceleration performance) dropped to 90% at 9% battery left. Drove only 85.9 miles from 100% to 9% battery. Took 45 minutes to recharge from 9% to 75% or so battery charge (but hey, they guy did get to eat a takeout “chicken dinner”..
GMC drove 155.8 mile 65 miles remaining using $5.39 Premium fuel per gallon took 17.371 gallons at $93.79, total fill up took only a few minutes. 8.9 MPG and was able to complete the full trip without needing to refill (wow, that thing is a fuel hog for a ½ ton, I just averaged 10.1 MPG overall on a 1600 mile round trip towing a TT loaded to 6500 lbs with my 2020 F250 with 6.2 engine).
Lightning charge cost $27 for the first charge, had to stop on the way back to recharge again since they did not wait for a 100% charge. They did not disclose total electric cost at the end of the video, but since they had to stop and recharge on the way back one can assume they spent close to another $27 for a total trip cost of $72.90 and spent a whopping 1.5 hrs sitting around waiting for the battery to charge.
As far as recharge cost being slightly lower, remember, there is no road fuel taxes on electricity, for now, so as reality sinks in, using a heavy EV truck towing realworld 6K trailer isn't going to save you money.
At 85.9 mile range I couldn't even get to any of the borders of my state without the need to recharge at least once and the whole way across my state would require at least three recharges :E
The same guys that did this video are currently attempting an adventure to northern Alaska with a super light weight pop up camping shell plus they will have a "support" hybrid F150 to charge the Lightning just in case (I suspect they WILL need it)..
Does it mean EV is wrong?
No.
But with current technology it is not scaling up to what the average user will want or need (full sized vehicles with real full size loads)..
