wildtoad
Jun 10, 2015Explorer II
Previous owner installed one and it works great. Gets the water really hot. Is only draws a few amps so it should not be a concern for tripping breakers. If you use a lot of hot water or need it quickly you may want to turn on both the electric and the gas. But for normal usage we only use the Hott Rod. They comment about not using an extension cord is so one doesn't use a cheapo one. Use a good quality cord rated properly and you should be fine.
44,071 PostsLatest Activity: Aug 16, 2026
