All is going well. Time is the biggest challenge. The spray foam is completed and wiring has started.
This is not going to be as extravagant as some posts here may suggest.
I have a 20amp circut under the counter for converter and water pump.
One 20amp on the kitchen counter.
There are three 15amp circuits for plugs. I haven't decided how many or where they will be yet.
Kitchen area and counter has started. I have to wait for two more items to arrive before I can finalize the counter shape. The two burner cook top and my grey water tank have not arrived yet.
I am having a hard time deciding if I want to install some used kitchen cabinets or just box some cupboards in with plywood and finish it with one side good oak vaneer 1/8" and use these cabinet doors I have. They are a Honey Oak stain. Seems easier to just frame with 2x2 and plywood it in. Once the oak finish is on it should look quite good.
What is a inexpensive ceiling panel to use? We have different stores up here in Canada but was thinkng of a basic white to add brightness. Some 4x8 panels are $60 each and would have to cut 1.5' off each one and throw it out. I think a $30 panel is just as effective.
I will be sure to get some pictures together eventually.
Thanks for all the great advice and knowledge.
