Redneck_bling
Feb 16, 2017Explorer
Oh boy...
looking at the 5th wheel plug from the front view, starting at the 1 o'clock position, that wire is orange, following clockwise direction with green, blue, Big white, yellow, ending with grey, at the 11 o'clock position. The center is small white with black stripe.
any IDEA whats what? This is the factory ford harness for a 5th wheel plug, to be mounted in the bed. I bought it for the plugs basically. I did not want to cut into my harness underneath. At the truck side harness connection, there are two plugs, Big white and Blue together going into one plug(2 pin).
The other plug(6pin) uses only 5 pins. They are: Green, Orange, not used, Yellow, Grey and White w/black stripe.
*The new lance harness has at 1 o'clock-green, 3 o'clock-yellow, 5 o'clock-#8ga black, 7 o'clock-red, 9 o'clock-brown, and center is #8 ga white.
I'm sorry my pictures did not go through. I tried copying links from google drive.
