2oldnslow
Feb 18, 2017Explorer
Tamnative wrote:
The reason for the Lance 6 pin plug is that the pos. and neg. wires are heavier than a standard 7 pin plug. If you are not going to use the same gauge wire that is on the camper you would be better off replacing the plug on the camper and leaving the truck plug alone.
That is how I did mine. The 12V function on the fridge didn't work well anyway, so why fuss with it? I added 6AWG wires on a separate connector (an Anderson plug) for battery charging for those cloudy days when the solar falls short (twice in 3 years). I have an isolator in that charge line on the truck.
