maria_bettina wrote:
Yes, I am bummed.
How many amp hours is the battery bank?
The rule of thumb is multiply amps by 10 to get the draw at 12 volts. This is due to inverters being at best about 88% efficient.
If the voltage on the battery is low, the inverter may well draw even more amps, causing the fuse to die.
Generally the inverter may be sized to do 125% of the load. 250 x 1.25 = 312.5 watts (so the inverter is busting its heart out trying to run that heater).
There are a couple of solutions.
1. connect the inverter directly to the battery posts. That will eliminate the fuse and amperage issues.
2. Use a 50 heating pad instead. You could run two.
3. There are 12 volt heaters available.
In any event the batteries are not going love running the heater for long periods of time.
My first battery bank was 875 amp-hours. Heaters were not an issue.
