time2roll wrote:
Amps x volts = watts. DC or AC works the same.
Always use 12 volts when calculating because that is where the power is coming from.
Otherwise need to plug into a 120v generator.
The 12 Volt Side of Life
This discussion has been eye-opening. !!!
I ended up calculating the DVD/TV draw, and it meshes with what I saw on the Renogy screen, ~3A. Which seems crazy high to me, but I gotta start thinking in 12 volts, which is clearly difficult for me to wrap my pea-brain around.
Thanks for the link. I will check it out.
