calamus wrote:
downtheroad wrote:
Welcome to the Forum...
I am a little confused by your question (I often am).
But, IF you are towing this trailer you certainly do need a battery so that your emergency break-away system will work...
The 12volt power for the break away hitch should come from the Pickup.
Both of our campers will run all the 12volt systems with out a battery. That being said not all of them do, check all fuses. good luck
No, power for the brakes on the trailer in a break-away situation is delivered by a battery on the trailer, not the truck.
