jdeco01's avatar
jdeco01
Electrical Problem Battery Draw
My 2007 Host Camper has a problem that I can't figure out. Any suggestions would be greatly appreciated. When not connected to AC or the truck, the generator not running, and the battery shutoff switch is turned to off, there is a draw on the battery of 1.5 amps, measured with a multimeter by disconnecting the battery ground cable and measuring the current between the cable and the battery ground terminal. What is particularly strange is that the battery draw will remain as long as I hold the probe to the ground terminal. When I remove the probe and then reconnect it, there is no current. Approximately 7 minutes later the battery draw returns. If I leave the battery cables connected, it drains the two 6 volt golf cart batteries in a few days, depending on how fully they were charged. As far as I can tell, the only circuits that are not disconnected by the battery cutoff switch are the jacks, slide outs, and converter/generator circuits. I have disconnected the jack circuits, but the battery draw is still there. I'm still trying to locate the controller for the slide circuits. However, the fact that the battery draw takes several minutes to return suggests to me that some electrical component is "resetting" during that period. Anyone had this problem or know the answer.
