Blazing_Zippers
Oct 11, 2015Explorer II
Electrical problem or ghost?
We have two five year old 6 volt batteries on our trailer. The other morning, the heater was going, and the water pump was cycling (it seems we need a new pump too). As the pump stopped cycling, all the DC power quit for a second, then came back on like nothing happened. We had one evening of a few hours of TV, limited LED lights, and doing dishes. What happened???
During this trip, I also checked the batteries a couple times with a volt/ohm meter-at the battery posts. They read no lower then 12.4 volts after two low usage nights. I also poked into the heavy wire insulation for readings, thinking the connections might be bad. Everything seemed to be pretty good. Both 6 volt batteries read 6.4 volts.
Any thoughts on the power outage?
