Boband4
Jul 20, 2014Explorer
Have you found the fuse/circuit breaker panel? If so, the converter is usually right there with them. Now that you have a new battery, check the voltage at the battery terminals while plugged into shore power. If you are seeing 13.4 volts your converter is charging. Then you would have to decide if you want to upgrade to a multi-stage converter.
