BradW
Nov 20, 2020Explorer II
Electrical Short Under Sink on 2019 1062 Lance
Other Photos
I have an electrical short under the sink of our 2019 1062 Lance. Apparently the black rubber insulation rubbed off of a multi conductor wire where it rubbed on the very sharp edge of some plywood.
We saw a flash come from that general area when the camper was very new and it blew a camper breaker, but I could never find the problem. The problem did not occur again until a few days when we plugged the camper in at home and it blew a 15 amp house breaker.
When I partially retracted the slide, the electrical short went away. So I knew it was something to do with the kitchen slide out. I again looked around in there and found the exposed coper wire were the insulation had been rubbed off. I can fix the wire if I can get to it.
Getting to it is my problem. My arms are not long enough to reach the wires very well through the cabinet door opening.
My question is: is there a way to remove the wood around the door opening to allow more room to reach in there?
Any suggestions are appreciated.
BradW
