Old-Biscuit
Oct 12, 2014Explorer III
The items that do NOT work.......don't work on battery power, don't work when on AC shore power and via converter OR don't work period??
Don't work period is easiest.....fuses. Either blown, or bad connections at fuse clips.
Changed out converter......did new converter come with dc panel or used old one?
Hooking battery up backwards and being plugged in shouldn't have fried converter.
Converter has 'reverse polarity' fuses (2 large ones typically 30A or 40A) that blow when battery cables are backwards
Anyway when you changed out converter......check that cables from battery are tight and connections on fuse panel are tight
44,066 PostsLatest Activity: Apr 10, 2026
