RetiredBeanCoun's avatar
Sep 06, 2019
Electrical Upgrade Made Easy
Just finished the lithium/inverter upgrade in my camper. It took a couple of hours and was so easy.
• Drop in as many lithium batteries as the battery compartment can hold, and keep existing DC cabling.
• Run a fused 2/0 positive and negative cable from batteries to the inverter
• Replace the solar charge controller with lithium compatible one (keep existing cabling)
• Cut the cable running from the automatic transfer switch to the AC breaker box and plug the two ends into the inverter.
• Done
Air conditioning, microwave, and all AC outlets work, and shore power and generator charge the batteries. It just seemed too easy. I have no electrical background so maybe I have it wrong.
Three 100ah Battleborn batteries
Victron Multiplus 3000 (Pre-programmed based on batteries)
100/50 Victron MPPTs (Pre-programmed based on batteries)
  • camperdave wrote:
    I'll assume there was one more step, remove the existing converter.
    That's a sweet inverter setup. All in one charger, inverter, switch yes?
    Did you retain any charging from the truck to the camper? Probably don't need it with the solar, right?
    The charge from the truck, I kept as it. I have duel heavy duty alternators so I assumed they could stand it. The concern might be the existing cabling since I would assume the lithium will pull a bigger charge, but it is fused and seems to be okay.
  • work2much wrote:
    Pretty much what I did aside from I removed the transfer switch since we don't use a built in generator. I also removed the stock converter charger since the new inverter charger has a transfer switch built in for when we are plugged in and it takes care of charging duties.
    Enjoy.
    On my exiting converter, I just flipped the 15 amp breaker in the AC panel that goes to the converter to off, since this is no longer needed. I am not sure that I needed to do this, but it is redundant so I did.
  • I'll assume there was one more step, remove the existing converter.
  • Pretty much what I did aside from I removed the transfer switch since we don't use a built in generator. I also removed the stock converter charger since the new inverter charger has a transfer switch built in for when we are plugged in and it takes care of charging duties.
    Depending on what kind of charging and inverting loads you are asking from your Victron make sure that it has good ventilation.
    Enjoy.
  • Nice! I did the same with lithium batteries and a Samlex unit. You'll be very happy with the performance no doubt.
