Lynnmor
Jun 02, 2016Explorer II
pianotuna wrote:
Hi,
The water heater cycles every 4 hours and runs for 15 minutes. That works out to wasting about 1.8 kwh per day.Lynnmor wrote:
The water heater won't use much more if left on, the only added electricity usage would be to make up for the heat that escapes thru the insulation.
There is absolutely no timer on a water heater. The thermostat turns on the heating element when the water temperature drops to a certain point. That temperature drop, when water isn't being used, is from heat escaping thru the insulation and other areas.
44,061 PostsLatest Activity: Apr 09, 2026
