MFL
Apr 20, 2022Nomad II
The reason it didn't have an off switch, is because it should not be turned off. It is designed to beep, when battery gets low, but most important is to save your life from CO. You should reinstall it, or at the least, buy a portable model, to replace it.
To answer your question, yes you can tape the wires off separately, to keep them from touching.
Jerry
Jerry
