peirek
Aug 12, 2013Explorer
canoe on top wrote:
If you have a proportional brake controller the brakes on the TV and the TT should work together. The TT braking is directly proportional to the braking of the TV. This being the case, and if the TT brakes are properly adjusted, the TT should stay in line when going down hill, even steep grades.
The TT brakes are designed to adequately brake the weight of the TT, not the combined weight of both the TT and the TV. I would suggest that doing this kind of braking will result in excessive wear on the TT brakes and you run the risk of them over heating and then, not working at all.
I live in CO and we have some pretty high, steep and long grades. I think using TT brakes in this manner would be potentially dangerous. I'm not talking about touching the brake controller to get the TT back in line, I'm talking about using the TT brakes for braking your total combined weight on a long grade.
You will not be a happy camper if you lose your trailer brakes on a mountain pass from over use.
(ellie007, I grew up in Yakima but it was many years ago)
x2
44,066 PostsLatest Activity: Oct 04, 2013
