BillB800si
Mar 06, 2015Explorer
This may help.
Website locations are mentioned at the end of each message.
Not sure about Dodge, but it sounds a lot like the TSC on my Ford. Unfortunately, I did have an experience and found out how the truck's system works. It does not prevent sway. What it does is help you maintain control once extreme sway occurs. We were on the interstate when an idiot driver decided to cut in front of me too soon. I had to evade and the trailer started swaying badly. The TSC kicked in and I could feel the trucks breaks working, first one side, then the other as I took my foot off the gas. I had the trailer back under control in no time. I still have a sway control system on my hitch that prevents the less dramatic sway from crosswinds and passing trucks and gives me peace of mind.
http://www.forestriverforums.com/forums/f2/dodge-ram-trailer-sway-control-tsc-system-21522.html
If equipped, the electronic Trailer Sway Control (TSC)
recognizes a swaying trailer and automatically applies
individual wheel brakes and/or reduces engine power to
attempt to eliminate the trailer sway."
"Trailer Sway Control (TSC) – If Equipped
The TSC system uses sensors in the vehicle to recognize
an excessively swaying trailer and will take the appropriate
actions to attempt to stop the sway. The system
may reduce engine power and apply the brake of the
appropriate wheel(s) to counteract the sway of the trailer.
TSC will become active automatically once an excessively
swaying trailer is recognized. No driver action is required.
Note that TSC cannot stop all trailers from
swaying. Always use caution when towing a trailer and
follow the trailer tongue weight recommendations. Refer
to “Trailer Towing” in “Starting and Operating” for
further information. When TSC is functioning, the “ESC
Off Indicator Light” will flash, the engine power may be
reduced and you may feel the brakes being applied to
individual wheels to attempt to stop the trailer from
swaying. TSC is disabled when the ESC system is in the
“Partial Off” or “Full Off” modes.
TSC is only active in the default “ESC On” mode. TSC
can be disabled by pressing the “ESC Off” switch and
entering “ESC Partial Off” mode. It is not active in the
“ESC Partial Off” or “ESC Off” modes. Refer to the ESC
portion of this section for an explanation of the different
ESC operating modes."
http://www.airforums.com/forums/f238/does-dodge-rams-integrated-sway-control-work-well-with-friction-sway-control-123858.html
44,070 PostsLatest Activity: Sep 18, 2026
