TheGreatWaz00ExplorerMay 27, 2015Empty Hot Water TankNew to Rv-ing and loving it. It will be a month or so between our trips so would you recommend draining the hot water tank between trips? I do not keep it heated while the camper is at home.
LantleyNomadMay 27, 2015I never drain. If you are on city water it is not necessary. Well water maybe?Would you drain your home tank if you left for a month?
Related ContentWater tank won't fillFilling and emptying water tanks at campemptying tanks ?Full or empty water tankGrey water tank won't drain completely
