TheGreatWaz00
May 27, 2015Explorer
Empty Hot Water Tank
New to Rv-ing and loving it. It will be a month or so between our trips so would you recommend draining the hot water tank between trips? I do not keep it heated while the camper is at home.
downtheroad wrote:I would drain it as well. They can get a smell to the water if it sits a couple of weeks. If you drain make sure your electric heating element is off and don't turn it on until you fill the water heater again.
You said a month or so....I'd drain it. 5 minute job.
