TheGreatWaz00
May 27, 2015Explorer
Empty Hot Water Tank
New to Rv-ing and loving it. It will be a month or so between our trips so would you recommend draining the hot water tank between trips? I do not keep it heated while the camper is at home.
Lantley wrote:No I don't drain my home water heater, at home I have a high end water treatment system.
I never drain. If you are on city water it is not necessary. Well water maybe?
Would you drain your home tank if you left for a month?
