TheGreatWaz00ExplorerMay 27, 2015Empty Hot Water TankNew to Rv-ing and loving it. It will be a month or so between our trips so would you recommend draining the hot water tank between trips? I do not keep it heated while the camper is at home.
pianotunaNomad IIIJun 06, 2015If the OP really wants, a small valve can be used in place of the drain plug.
Related ContentWater tank won't fillFilling and emptying water tanks at campemptying tanks ?Full or empty water tankGrey water tank won't drain completely
