potterkevin's avatar
potterkevin
Emptying a portable sewer tote
I will be parking my TT for the season on a lot that doesn't have sewer hook up. I'll empty the holding tanks into a sewer tote and haul it to the dump station at the bathhouse. So my question is, can I accomplish the emptying of the on board tanks into the portable tote and emptying the portable tote into the dump station using the same hose. I don't believe I can, but I looking for suggestions. I know I need one hose with bayonet fittings on both ends to hook to the TT and the tote. Then I need a second hose with a bayonet fitting on one end hooked to the tote, and an elbow on the other end to position the hose in the hole at the dump station. Is there a way I can accomplish my task with a single hose by changing out ends or something? Or any other recommendations?
  • If the dump hole is big enough to swallow the bayonet, you'd be in clover. Or, simply hold it over the hole yourself. I guess if you want the constant hassle of changing out the fittings, that'd work too.
    If the dump hole is at the bottom of a concrete slope, you can just dump the tote out directly on that sans hose.
