bowler1's avatar
bowler1
Endless Breeze 12 Volt Fan????
Hi,
Does anyone have one of these? And if so what is your impression of this fan versus regular AC table top fans?
I read great reviews about this product and how powerful it was so I got one. I tried it out today and I am seriously underwhelmed to the point that I wonder if there is something wrong with it.
On high speed the fan delivers a very light air flow. If I stick my hand by it is even slightly hard to feel. I ran it on high in my camper on the nightstand right by the bed and if I lay on the opposite side of the queen size bed I could not feel the air flow.
My cheap $9 table 8 inch table top fan on the low setting was fairly comparable (running on a cheap plug in converter in my trailer--only can get it on the low setting like this).
Is there maybe something wrong with it? The blades move fast but don't seem to produce much air flow.
Am I expecting too much out of a 12 volt fan? I could run a small conventional fan off the 12 volt outlet using a converter. I just don't see why that would necessarily blow more air than this.
  • I bought one of those about 2 years ago for a special outdoor function. When it showed up, I tested it for airflow and how long my battery would run it. I was very surprised at the amount of airflow and how long the battery could keep it going. I'm pleased with the product. Perhaps you have low voltage to the fan if it is not working well.
    -Added on edit-
    No, it does not perform as well as a 120 Volt fan, but if all you have is 12 Volts, it is a miracle.
