turboo wrote:
http://www.torklift.com/index.php/products/suspension/stableload#a7311
At the risk of being completely wrong , as I am by no means a suspension expert , this type of spacer seems to alter the spring dynamics in a negative way . In a spring pack the leaf above is in continuous contact with the one above over it's entire area . It seems that the lower overload leaf is meant to perform the same way , when the spring pack is loaded it will lay on the overload over it's whole length . With the Stable Loads , or similar ,it will have a point load on the spring pack above . I realize that leaf springs are not perfectly seated on each other but the principle is there .
