Sliding-into-ho
7 years agoExplorer
Not sure upper stableloads are right for me (UPDATED)
(UPDATE 10/23/2019 here: http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29794168/gotomsg/29988533.cfm#29988533 Safe to say the upper stableloads were NOT causing any issues that I didn't have already, but the stock shocks very likely were. Upgrades continue! Big thanks to the massive wealth of knowledge on this board. In the first page of responses alone, pretty much all the relevant considerations were addressed. You Rock! Thanks also to Torklift who reached out and went the extra mile to help me get dialed in.)
Rig: 2017 F350, SRW, FX4.
Tire sticker 3243lb
Rear GAWR: 7230lb
TC: NL 9-6, 2600 Dry, 2900 Wet
The only suspension mod the dealer installed is upper stable loads. I wanted the lowers, but they said they don't install them because they don't want to deal with the drilling.
I've never hauled a TC before, but plenty of heavy trailers. The stable loads don't feel quite right. If you've ever ridden in a New York taxi cab in the 80's or 90's (you know... the Ford Tauruses and Lincoln Town Cars with shot suspensions), that's sort of the sensation: floaty, bouncy, vague, disconnected.
I wouldn't say there's a lot of sway in terms of magnitude of movement, but when it does sway, it bounces back and forth from side to side.
My hunch is simple: my rig may not be quite heavy enough to warrant full size stable loads, which engage too much of the upper overload spring (lower spring rate) and not enough of the higher spring-rate lower overload. I suspect this is why Torklift unequivocally recommends lower stable loads first. But to be clear, I don't have any experience with this and these are just guesses.
The rear fender is 1-2 inches higher than the front fender, depending on the load, for what it's worth.
Here are a few things that I would try next, but if you feel like you know a more ideal solution, please let me know:
1. Remove stable loads and get a baseline for how the truck handles fully stock. After all, I'm under my door sticker weight (I've removed a propane tank and the heavy rear patio).
2. Shave an inch or two off the stable load blocks
3. Uninstall stable loads and, assuming too much sag/roll, upgrade shocks to rancho adjustable and add Hellwig Big Wig.
4. Last option would be air bags, which would probably only need minimal inflation.
Thanks in advance for any thoughts!
Tire sticker 3243lb
Rear GAWR: 7230lb
