Halmfamily wrote:
My GMC 3500 has the Duramax/Allison combination. We keep the truck in tow/haul mode whenever towing. On downhill grades the transmission locks the torque converter and then downshifts to maintain speed. I just tap the brake as needed and the will downshift to maintain speed. I believe the turbo also acts as an exhaust brake while in tow haul, someone correct me if I'm wrong. I can keep speed on long grades without having to worry, have actually had excelerate at times to maintain speed.
I have a 2012 Chevy Duramax/Allison and keep in tow/haul mode too. The compression brake only works when you have the transmission in tow/haul mode. On my truck, it's a button below the radio that turns it on/off. I use it when going down steep grades as it works with the transmission to maintain speed. It is an engineering marvel in my mind, it works just like a cruise control. It's very steady and I love that feature. I don't leave it engaged all the time, only when going down a steep and/or long grade.
