Ponzo
Dec 22, 2013Explorer
engine oil level
I have an '03 Ford with the 6.0 diesel. At oil change time the level is higher than it should be. The dipstick is not milky like there is water or coolant getting in. Can this be fuel getting in someh...
mr. ed wrote:Lynnmor wrote:
Agree with the lab tests. However you might have been overfilled when it was changed. My "Quality Plus" Ford dealer put in 2-1/4 quarts too much of the wrong oil at my first oil change.
That's one reason I change my own oil. When the truck was new I had Walmart do the change as I watched. The employee proceeded to add a 13th quart of oil whereas my truck uses 12 quarts. If I hadn't stopped him the oil would have been overfilled.
BTW, When allowable I always watch the mechanic whenever my truck is worked on for any reason.
