Bednarski1
Mar 04, 2014Explorer
Engine Oil
I have a Ford 2014 Sunseeker and I was wondering how many of you use a synthetic oil. I would like to start out with my first oil change using a synthetic. Thanks for all the good advice.
Its_Hondo wrote:Don't think you will go wrong with Mobil 1. I use the Mobil 1 5w20 in my Ford V-10 E-450 Class C.
I just did my 1st oil change on my 2005 Chevrolet 6.0.
Wal Mart had a 5 gallon jug of Mobil 1 5W-30 for about $25, so I decided to give it a try. I used a AC Delco filter though I usually use Purolators.
If the engine likes the oil & doesn't consume any, I'll stay with the Mobil 1 and change it every 6,000 miles (3,000 mile filter change) or each spring before the season starts.
If it uses any oil then I will try straight 5W-30 dino oil & see how it goes.
pnichols wrote:
I use Mobil 1 EP (Extended Performance) in our Class C's V10 engine. I switched from standard Mobil 1 to Mobil 1 EP some time ago.
I also use Mobil 1 EP in both of our motorhome's generators. Along with Mobil 1 EP, I also use special spark plugs in both generators. The generators run quieter, smoother, and probably more efficiently ... using both the synthetic oil and different spark plugs.
Bednarski1 wrote:
I have 2800 miles on it now and was planning on switching in the next couple weeks to Mobil 1 Full Synthetic. Should I wait a longer time to switch? What do you all think. Thanks for all the great advice.
