I have an '03 Ford with the 6.0 diesel. At oil change time the level is higher than it should be. The dipstick is not milky like there is water or coolant getting in. Can this be fuel getting in someh...
With my Walmart experience they want to put in 15 qts. and I have to sign a waver for the 13 qts. Then they have a fit after they run the engine and check the oil and nothing shows on the dip stick. Also have to check after the truck sits over nite.
