twodownzero
Jan 11, 2019Explorer
mkirsch wrote:
Also out of that $3000 comes any gaskets, hoses, cables, fluids, and other parts that should be replaced as a matter of course in a proper engine swap.
If you're doing it yourself you can take all the shortcuts and make the professional mechanic look like a crook. However if anything goes wrong due to those shortcuts, you've got nobody to blame but yourself. ANYTHING goes wrong with the professional job, you'll be blaming the mechanic for taking shortcuts...
A new engine has a warranty, sometimes even one that covers the labor if the engine fails. As long as you didn't get it hot or run it without oil, it'd be pretty hard to screw this up!
44,070 PostsLatest Activity: Jul 01, 2022
