Safariscout1974's avatar
Aug 25, 2014
Entry Door Hinges
Hi. Have a 2012 Starcraft Autum Ridge 336 RESS and the door hinges have ceased up.|The dealer is 1500 km away so it is cheaper for me to fix it (yes under warrty but cost of fuel & ferry would be $1500...one way). So my question is can you buy the door hinges (main door & screen door), or do you have to buy a new door? Thanks for any advice you can give.
Regards
Greg Harris
  • Greg,
    Have you tried soaking them with a rust penetrant? Mine were very stiff and I freed them up by using some rust penetrants and lubricating oil. They now swing easily.
  • In the same process right now.
    I contacted Tiffin. Our hinges are no longer made. Phillips was the hinge manufacturer.
    However, Tiffin Parts service is sending me three hinges that replaced our current hinges. They believe they will work.
    Tiffin gave me dealer cost for each hinge which is $37.83, retail was $53 and change.
    Doors are not cheap. I did a temp repair on the hinges, which snapped until I receive the new hinges. If the hinges they send don't work, then the only alternative may be a new door with framework. Not Cheap. $400-800, depending on where you look. Before I replace the door, think I'll try to locate a surplus/salvage source.
    Contact your manufacturer. As your unit is under warranty they may send you new hinges without any cost.
    Good luck. PITA for an entry door.
