Gaffer222's avatar
Gaffer222
Equal-i-zer Hitch question - Keystone Terrain 250TRS
Signed the deal today for a factory order on 2014/2015 Keystone Terrain 250TRS. Not sure what model Year will be on the VIN.
Question is does anyone have the same TT with a Equal-i-zer Hitch. I plan on ordering the 1k/10k model and assume the standard shank will be what I need. TV is a 2007 Ford Expedition.
I can figure it out on the EQ website if anyone has the
"Coupler Height above ground with trailer parallel to ground"
  • I had the same question about the coupler height when I bought my trailer. I called the dealer and the salesman grabbed a tape measure and measured one on the lot. If they have a similar model they'll probably do the same for you.
  • You should be good with the standard shank. The receiver actually sits kind of high on the Expy so you might be at the lower holes of the shank. Once you get it home double check all of bolts on brackets mounted to the a frame. Some of mine were loose after the ride home. Also double check to make sure they mount the brackets in the right locations. Mine were installed to close to coupler.
    By the way, good looking TT you got.
