jbres
Sep 28, 2014Explorer
Equalizer Adjustment questions round #3
Stopped at the Indiana weight station near my house for hopefully the last and final time. Trying to get my Equalizer E4 adjusted "perfect".
First time after I had dealer set up my system, I weighed and was restoring all weight to front axle of truck except #200 pounds. Towing in wind pushed my 2500HD and TT around enough to not making towing comfortable at all.
After I made adjustments WITHOUT even adding washers, I then restored all weight to front axle of truck except #180 pounds.
After adding 1 washer, I now am at 7 total washers and now am restoring all weight to front axle of truck except 120# pounds.
My question is do I need to restore ALL FRONT AXLE WEIGHT and get that number to zero? Or is it sufficient what I have?
Trailer sits slightly nose down, and truck is sitting level.
My equalizer bars aren't EXACTLY parallel to trailer frame, they appear to be SLIGHTLY pointed up on the back side, pointed up towards trailer, not towards ground.
Opinions? Advice?
Thanks!
Opinions? Advice?
Thanks!
