opnspaces
Nov 05, 2014Navigator III
I'm assuming from your post that the trailer is parked until spring. If I was in your shoes the first thing I would do come spring would be to weigh everything. From there you will hopefully have an idea which way to go.
I can't help but wonder if you are just tongue light. If this is true you'll never be able to adjust the sway out of the hitch. A trip to the scales will answer that question.
As far as the popping and groaning, that it the hitch doing it's job. Removing a washer to quiet it down will most likely also remove whatever little bit of sway control you currently have.
44,070 PostsLatest Activity: Sep 18, 2026
