Ron3rd
Nov 06, 2014Explorer III
Whitehawkmn wrote:
Thank you all for your ideas. And yes I did follow the instructions on setting up the hitch from scratch. But when I do, that's when I get more sway. In the spring I'm going to try a few different things. I may look at going back to what I had and taking out 1 washer to help with the grinding and popping.
Be aware that if you take out a washer you will reduce tilt in the head and remove weight from the front end. Usually not good. The popping and grinding is normal as the EQ is probably the noisiest hitch on the market.
44,070 PostsLatest Activity: Sep 18, 2026
