RinconVTR wrote:
Ron Gratz wrote:
RinconVTR wrote:
Do not lube the bars at the L brackets as this IS your sway control for this WDH design. Decrease friction at the L brackets, decrease sway control. The two are directly related.
For the 4-Point Equal-I-zer hitch, the majority of the sway-resisting torque is generated at the contact surfaces between the socket and hitch head.
The friction force generated at the L-brackets is a relatively small amount.
Ron
You obviously have never owned one, or you would not state such non-sense. The ball sockets are indeed defined at part of the "4 point" system, but have little to no effect on sway in reality vs marketing.
The ball sockets (trunnion knuckles) allow the trunnion bars to articulate left to right, they DO NOT resist trailer sway at all. Driving in a straight line, there is ZERO movement at the ball sockets. Sway control on such systems like the E2 and Equalizer is 100% on the L brackets.
In fact, you have done a few calculations (that I am not in 100% agreement with) regarding forces at the ball with WDH applied that could also be used to estimate forced at the L brackets or chains. There is great force on those bars at the L brackets, and I cannot believe you of all people think metal on metal friction in the area contributes less than lubricated ball sockets that hardly move when trailer sway occurs.
Ever notice that out of the box, the friction area on the bars that meet the L brackets is unpainted? But the ball sockets and all of the trunnion head (hitch) are fully painted? Hmmm. That alone should tell you all you need to know.
Maybe you should take another look at the Equal-izer brand WDH. Maybe read the manufacturer's literature also. You are incorrect.
