GeoffW's avatar
GeoffW
Equalizer Hitch Set up on Banshee B-3??
I am wondering if it is at all possible to get a Husky Equalizer hitch set up on a 2011 Palomino Banshee B-3. It appears this cannot be done with out some major mods to the frame, and that is not something I want to get into.
If anyone else has one and has some info to share on this, that would be great!
  • The reason is if you put any form of ATV, so say around 400#, you severely increase your tounge weight. Same as if you load an ATV into the box of the truck. So I may just look at getting air bags. It does not sag the suspension out totally, but I don't like the springs being over compressed. That is why I am looking a couple options. It looks like it will be impossible for an EQ hitch. Thanks for the input!!
  • I agree with downtheroad, unless you're seriously downgrading to a much smaller tow vehicle, you shouldn't need a WD hitch.
  • Not sure you would even need one...Pop up with fairly light tongue weight.
    We towed our pop up for years with a Ford Explorer and no WD hitch.
    You have a good solid truck.
