Kayteg1
Dec 04, 2020Explorer II
noteven wrote:
RV furnaces are probably 80% efficient..
In your dreams.
I took my furnace apart for electronic board replacement, only to discover that hot air straight from the burner was directed onto outside cover, what is steel plate with no insulation on it.
So the hottest air from the burner was used 1st to heat the outside skin on the camper.
75% efficiency household furnaces have exhaust cold enough to use plastic pipes.
Try to put your hand at TC furnace exhaust? Better not !, but use infrared to check it.
I would estimate that the standard RV furnace has efficiency below 30%.
44,057 PostsLatest Activity: Mar 12, 2026
