StirCrazy's avatar
StirCrazy
Moderator
Dec 02, 2020
Espar type heater to replace older furnace.
I was just wondering if anyone has chaged out there propane furnace for a diesel type. I am thinking of doing this as my propane furnce is getting old, uses a lot of propane, uses a lot of power, is noisy and had a very wide swing from freazing to roasting. also as it is a direct vent it doen't realy heat up the bed area much.
what I was thinking of doing was getting an espar type heater putting it where the furncase was and use a split outlet to direct a bit of heat up to the bead area while leaving most to go to the main cabing area. was even thinking of maby taking three branches off and put one to the bathroom.
the main question I have is how do you size them? I have a 1991 10foot slumberqueen with a east/west queen bed. there seams to be 2Kw , 3Kw, 5Kw and 8Kw sizes .
also the opinions out there is to get a little larger than you need so it is running at a slower speed using less power, fuel and making less noise. but if you get to large then you will cook your self out running on minimum.
everything I have read (from van sites) shows me they will use 1/3 to 1/2 the power of my present furnace and make a lot less noise.
just looking for real experiances in a TC and advice one way or the other.
thanks
Steve
  • I have been considering adding a diesel heater to supplement the lp furnace in my truck camper. I don't think i would remove the old furnace though.
