Dtaylor's avatar
Dtaylor
Eternabond ??
I thought the stuff would have been thicker. It's only about a 1/16 inch thick. Anyway, I plan to use this where the back wall attaches to the roof. Can I overlap this stuff over the edge without it running down the outside of the wall?
  • therink wrote:
    There is a 1/2" or so plastic trim piece that runs side to side along the rear of my roof. I ran the tape right up to the back edge of the plastic trim (exactly even with the edge). I didn't curve it around the back edge as I didn't want it to be visible from the back (if this is what you are describing).
    Yes. I think after taking a second look, I will probably do it like that so it is not seen.
  • Don't worry about the thickness of the material.
    It is a great product. Make sure you use a metal roller.
    You will have no regrets with Eternabond.
  • There is a 1/2" or so plastic trim piece that runs side to side along the rear of my roof. I ran the tape right up to the back edge of the plastic trim (exactly even with the edge). I didn't curve it around the back edge as I didn't want it to be visible from the back (if this is what you are describing).
