Well just found an area between 2 of the slide outs that looks like it is leaking from the roof. Getting some Dicor for a quick fix but would like to Eternabond all of the seams. Does anyone have pict...
I will also add, after you are done putting the Ebond tape on, applying a thin film of Dicor on the gray Ebond sealant exposed edge of the tape will help stop dirt from sticking to it.
Cleaning and prep are paramount for the E bond and will take some time, but the end results are worth it.
