gbopp
May 02, 2017Explorer
Steven0110 wrote:
THis is for compartment leak on front where front overlap covers rubber roof. I am told I want to tape this; which tape product?
Eternabond Roofseal. White, 4 inch wide if you can use it. If not 2 inch and overlap it as needed.
Use a roller. I prefer a steel roller, I think it does a better job.
Some prefer a wood roller.
After applying the Eternabond, I run a bead of Dicor caulk along the edges. It just makes it look better, it is not necessary.
If applied properly, the Eternabond will NOT leak.
Clean the area well before applying the Eternabond.
