icanon wrote:
Is Eternabond a better method? I don't know, is Eternabond life span worth it? Is Eternabond once weathered, worn or damaged is it easy to remove, replace or repair? Does Eternabond preforms well under hot to freezing temperatures to driving couple thousands miles per year with all vibrations twisting etc. I too, have questions on Eternabond and very interested in this product but still weighting on whether I should use it or not. Hopefully some can provide some insight on this product.
Thanks
While the manufacturer will not warranty it for 25 years, they say that properly installed it can last that long. I believe it. Once that stuff sticks, it is REALLY hard to get off. I used it on a previous trailer after repairing a small roof leak on a seam. 4 years after the repair I traded the trailer and it looked as good as the day I put the tape on. It's an excellent product. Do a forum search on it and you'll dozens if not hundreds of positive testimonials.
Again as the company itself says, proper installation. It's not hard but the prep work is critical.
