ticki2
Mar 06, 2022Explorer
If you do decide to charge from the truck alternator you should disconnect the charging after the batteries are fully charged as lithium batteries should not be continually charge after full charge . Another temporary alternative would be to use an extension chord to the present converter ( if it is lithium compatible ) to a 220v outlet in your house . You may need adapters to the European plug .
