Kayteg1 wrote:
work2much wrote:
Is it just me or does it seem like posting here can be pretty glitchy? Maybe it's safari but often when trying to publish a post it hangs up and I have to rewrite from scratch. Must remember to copy post before submitting....
If you are using rv.net site, it does not allow percentage symbol and that is what happens to me. I have to use woodals site, or type it in words.
Someone posted that those things can use over 5 gallons of water per day, so you need good water supply.
And again, the main hassle is to run the unit dry before driving, or you might get showers inside.
I noticed all our County Animal Control trucks use those coolers.
Bay Area is not the best for evaporative coolers, but looks like they work for animal cages.
Thanks for the info. I didn't know there was a mirror site. will check it out.
I think coming up with a way to effectively drain the pan without getting on the roof and removing parts would have to be mod #1
