_DJ_1
Feb 10, 2016Explorer II
steeds wrote:
this is from an rv place near my city. the guy told me another f150 customer bought this camper.
he has airbags on 30psi, then lowered 20 psi he said because it was too high. so I'm assuming air bags yes would be needed.. but maybe not as much as i suspected.
and i believe this was the 770r model ? mine if i get it ( 625 model) it should be lighter then this.
I like it!! Thanks to Ford"s 6'9" box you can close the tailgate on a 6'6" camper or even a full sized quad. You very well may need air bags. Not so much front to rear but side to side. Most of these campers have all the appliances, water heater, etc down the driver's side. With a lighter truck like the F 150 you may see a slight sag to the driver's side. If you do use bags make sure to plumb them separately so you can adjust the pressure accordingly.
44,056 PostsLatest Activity: May 04, 2014
