danimal53's avatar
danimal53
exchanging propane cylinder that came with TT
I recently tried to have my 20lb propane tank refilled and it wouldn't fill. The person filling it determined it must be a bad valve. She proceeded to fill a second tank I had without issue. So my question, is there any reason NOT to just exchange the cylinder for a full one (at Menards, Walmart, etc)? I understand it's more costly, and you get less propane than if I did a refill. But is there any reason to keep the original that came with my TT? Or just exchange it and move on?
  • If you are going to replace with new, I suggest getting one with a built in float gauge. The gauge makes it simple to get an idea of how much is left in the tank. I really like the 2 I’ve got.
  • I've switched old tanks for new ones at exchange places a couple times.
    Years ago, when "they" changed from the rounded valve knob to the triangle valve knob style, my old tanks with the rounded knob could not be refilled. So I just exchanged it at one of those places for a new one with the triangle valve knob. End result, I had a tank I could now get refills on, and didn't have to exchange. I cleaned up all dirt and gunk on the new tank and it was still on the ol' pop-up when we sold it.
    Did the same thing for an old tank on a BBQ grill. No one was the wiser, and I didn't have to buy new tanks.
    Besides.... if you don't exchange the tank and you buy a new one, how are you going to dispose of the old one that's defective? You'll need to find a recycling place for hazardous materials, which most cities have. But still, that's going to take extra effort and time away from CAMPING!
  • When I last had a tank go bad, the replacement had a different height collar on it. So I needed to buy two in order for them to mount on the tougue tightened down properly.
    This was with 30s but, I have 6 extra 20s that I bring along for extended cold weather trips, and the collars on them vary as well. Not a big deal for me, as I just remove the 30s when I set up camp, and set the 20s in the tray. I use the 20s first, so I can have the 30s mounted in place for the trip home.
    So that is the only potential problem I see with your plan.
  • Exchange it and move on. The other option is to buy a new tank. That will cost you more than than exchanging and getting a 2/3 full tank.
  • Exchange and move on. The one gotcha is that those exchange tanks are usually old, and some places won't refill them due to age. Most places will fill without a second glance, but a few won't.
