jerem0621
Dec 09, 2015Explorer II
Turtle n Peeps wrote:jmckelvy wrote:
I assume it is gas powered? If so remove the Idle Air Control Valve on the throttle body and clean with carb cleaner. Also clean the throttle body and any passages associated with the IACV.
This is where I would go first.
That fixed my 4.6 Modular V8 in my Fabulous Town Car from a very similar issue… Only difference was mine would howl like a trumpet, and die, and idle rough.
Just a hint… disconnect the battery before you replace the IAC…
Could also be a fuel filter.. chances are you need to replace it anyway.
Thanks!
Jeremiah
44,070 PostsLatest Activity: Jul 01, 2022
